loft command: dependence between solid and profiles
Hi all,
anyone knows if it is possible to make a depencende between the solid and the profiles that you use for the loft?
So when I modify a profile the solid adapts automatically.
Or has anyone generally experience by making the workflow with the command loft automatically?
Regards
Andreas
Howdy, Stranger!
