Supported Communicator file import and export versions
Is there a way to query Communicator for a list of supported formats and versions? For example, the help.bricsys.com Communicator article shows "SLDASM, SLDPRT: Solidworks" but not the release versions of Solidworks which can be imported.
I have a colleague who needs a Solidworks 2020 file converted to STL for a prototype run but I'd rather not execute a non-disclosure agreement only to find out that I can't import and convert it for him.
I'm sure that this is something which the developers know and also sure that asking each time this may come up "Is (year/release) of (program) supported?" will get an answer. It would be awesome if the COMMUNICATORINFO command could be extended to support this, though.
The latest I can see from the release of note of 16.04.2019 is - Communicator now supports the import of SOLIDWORKS 2019 formats.
Maybe it is better to submit a support request with this question to get the latest update - https://www.bricsys.com/en-intl/support/#13
