2d constraints in 3d space
Hi all,
I want to work with parametrised 2d sketches in 3d space. But it doesn't really work...
Is it possible to put 2d parameters on a 2d profile which is not in the x-y-level?
And can I parametrise a 2d profile and then move it in the 3d space?
Or how do you work with parametrised 2d sketches in 3d space?
Regards
Andreas
@andreas_p said:
Is it possible to put 2d parameters on a 2d profile which is not in the x-y-level?Yes. But you first have to align the UCS with the profile's plane.
Note:
Using 2D constrained sketches as the basis for 3D models does not work in BricsCAD. The 3D models will not be parametrically linked to the sketches.0 -
Ok thank you.
On a vertical 3d surface of a solid it works.
But it doesn't work with an aslant surface of a 3d solid. And also not with any 2d profiles.
What could be the problem?0 -
From your description it is hard to understand what you mean. Please attach a DWG.
See attached DWG for an example.
In this file on the left side there is an aslant rectangle and on the right side there is a solid with an aslant surface.
And with both planes i can't align the UCS...0 -
Using the _Entity option of the _Ucs command you should able to align the UCS with the polyline.
The slanted face of the solid, although almost flat, is a spline face. So you cannot use the _Face option of the _Ucs command. But the default option of the _Ucs command: click 3 points to specify origin, X axis and Y axis, can of course be used.
You may also consider using the _DmSimplify command:
: DMSIMPLIFY Select entities to simplify or [Entire model/SEttings] <Entire model>:_SEttings Simplify [Geometry/Topology/Back] <Back>:_Geometry Enter geometric simplification tolerance or [ON/OFF/Topology/Auto] <Auto>:4 Simplify [Geometry/Topology/Back] <Back>: Select entities to simplify or [Entire model/SEttings] <Entire model>:
Thank you.
On the surface of the solid it works when I use the DMSIMPLIFY command.
But with the polyline it still doesn't work...0 -
You need to get better acquainted with the _Ucs command.
After choosing the _Entity option make sure you select the polyline by clicking its outline.0 -
My mistake was to select the command "Align UCS to Face" instead of typing _ucs
