Explode dynamic blocks creates invisible objects
I have a drawing with Autocad dynamic blocks, using "visibility". When I explode this block in ..
- AutoCAD: only the visible things are displayed, the rest removed
- Brics 18: invisible parts stay invisible and the explorer makes no difference
- Brics 19: invisible parts stay invisible, but the explorer shows a difference and offers options
Now I suppose that we have a huge lot of drawings with these invisible objects, and I have 2 questions:
a) How to set Brics 19 that invisible parts are not created, but removed when exploding?
b) How to clean up the existing, messed up drawings?
Thanks
Peter2
as to a):
To my knowledge impossible. Maybe you should open a support request, so this behavior can be corrected in future versions.as to b):
You could define a command that deletes all hidden objects from a file, e.g. like this:(defun C:PurgeHiddenEntities ( / selset n count entnme entdat bit60) (if (setq selset (ssget "X")) (progn (setq n 0 count 0) (repeat (sslength selset) (setq entdat (entget (setq entnme (ssname selset n)))) (if (and (setq bit60 (assoc 60 entdat))(= 1 (cdr bit60))) (progn (entdel entnme) (setq count (1+ count)) ) ) (setq n (1+ n)) ) (princ (strcat "\n " (itoa count) " hidden entities deleted.")) ) ) (princ) )
Use with caution (backup your files first) and completely on your own risk.0 -
thanks - works fine. I will set a support request.
