Tool Palettes with Text and Separator
I find the Text and Separator in the Tool Palette hard to use. Once you have created a Text or Separator you cannot move them around in the palette. A workaround is to edit the ".btc"-file.
Text and Separator also create their own panel with scrollbars. Se attached picture. Palette on the left is from AutoCAD, right from BricsCAD. I want the Scrollbar to be part of the hole palette not just the panel (subgroup).
I use the V20 version of BricsCAD (20.1.08).
Anyone can help me?
Regards Ole
Good news, this has been fixed in version 21.1.05-1
