Disable Extention lines in opposite direction
Does this occur when using shades of grey and Modelling styles?
How far is your model from UCS 0,0,0.? Try moving your model to UCS 0,0,0. You can get weird results like lines showing through if you are far from origin.
Thanks for the search.
None of these settings help.
Tried restarting BricsCAD and the model, purging and audit.
Nothing helps.
The fact that models are not close to 0,0 never was a problem in DWG (as long as everthing is relative close to each other.)However.. I think this in the DWG model!
Others don't seem to have it (anymore?)
Maybe someone else sees these0
