freezing layers in ALL viewports in a drawing
how can i select a layer in a viewport and freeze it in all viewporets in a drawing?
i have looked at vplayer, and a few other suggested commands, but all only freese in the current viewport.
this is possible in autocad in the layer menu by right clicking on the layer, going to freeze > all viewports.
with 75 sheets in a dwg file and about 80 odd viewports, this will be a very long slow task to complete every time a new layer is added to an xref and reloaded
i have been googling for a lisp routine ot layer tool but have not been able to find a solution.
daz
: VPLAYER [List frozen layers/Color/LineType/LineWeight/TRansparency/Freeze layers/Thaw layers/Reset layers/New frozen layers/Default visibility setting]:f Select the layer(s) to freeze: MyLayer Specify viewport(s) [All/Select/Current/eXcept current] <Current>:all [List frozen layers/Color/LineType/LineWeight/TRansparency/Freeze layers/Thaw layers/Reset layers/New frozen layers/Default visibility setting]: :
The attached LISP allows you to select the entity on the layer that you want to freeze in all viewports or in all viewports except the current. Uses
VPLAYERIn AutoCAD there is an option to access these options from the
Layers panelby right clicking on the layer name. Unfortunately BricsCAD doesn't currently do this.Regards,
BricsCAD V20 Ultimate
CAD Concepts0 -
thank you SO MUCH.
exactly what i was after.
daz
following up on this question. the above worked when it was a layer in the drawing
but when its an xref. the whole xref layer is removed. i just want to freeze a single layer in the xref. not ALL the layers in the xref.
does the latest version of Bricscad do this? if so, i will upgrade our licenses.
daz
