Moving VBA Application to c# - AutoCADEntity Array
I'm trying to bringt this VBA code to c#:
Dim Segments(1 To 12) As AcadEntity
Dim MP1
Dim P1, P2
'1. set center point MP1
MP1 = ThisDrwaing.Utility.PolarPoint(EP, radians(90), D2half + radius)
'2. draw an arc with given Values and add it to Segments array position 1
Set Segmente(1) = ThisDrawing.ModelSpace.AddArc(MP1, radius, radians(-90), radians(-halfOpeningAngle))
'3. get the Start Point of the drawn arc stored in Segments 1
P1 = Segmente(1).StartPoint
'4. get the End Point of the drawn arc stored in Segments 1
P2 = Segmente(1).EndPoint
How far I've come so far:
//1. set center point MP1
Point3d MP1 = new Point3d(0, 0, 0);
MP1 = PolarPoint(öv_EP, radians(90), d2half + radius);
//2. draw an arc with given Values and add it to Segments array position 1
//Create entity array for 12 entities first. I need this to be able to mirror all the 12 entities to draw the final structure.
Teigha.DatabaseServices.Entity[] Segmente = new Entity[12];
//store an arc in Segements[1]
Segments[1] = new Arc(MP1, radius, radians(-90), radians(-halfOpeningAngle))
//Draw the Arc
using (Transaction action = manager.StartTransaction())
BlockTable blockTable = action.GetObject(database.BlockTableId, OpenMode.ForRead) as BlockTable;
if (blockTable == null)
throw new System.NullReferenceException("blockTable == null");
BlockTableRecord blockTableRecord = action.GetObject(blockTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
if (blockTableRecord == null)
throw new System.NullReferenceException("blockTableRecord == null");
blockTableRecord.AppendEntity(Segments[1]);
action.AddNewlyCreatedDBObject(Segments[1], true);
//3. After the arc is drawn, the entity should have a start and end point, right?
How can I now access the Startpoint of Segments[1] like I marked in the image ?
