sum of distance/ length annotations
Is there a routine that sums numeric text entries please?
I have need to obtain the sum of straight numeric entries in a dwg.
Not the total number of entries but the sum of the numeric text
Egs Sum of 300.25 and 500.08 and 100.25 = 900.58
I'm just after the total as a single text entity
I Googled but the word add and sum takes one all over the place!
You can sum numeric entries in a table in Brics CAD. But I think that if you just enter text or multitext in the viewport, then CAD just recognises it as a string of text and not a numeric value.
If you are trying to sum the lengths of lines or some other geometric object then there are other ways.0 -
Richard,
If you type in Sum Text Autolisp into a search engine, you should get quite a few results applicable to your requirement.
One that springs to mind is: lee-mac.com/textcalculator.html
Many thanks to both of you for taking time to reply.
David the lee-mac routine looks to be it.
I did find others.
Marvellous thing Google when you ask the _appropriate _question.!Again many thanks
