Hi All
Is there a comprehensive Help file / link which outlines all the setvar and their descriptions. I guess I could use the Autodesk help files for most but will help a help file / link for the custom BricsCAD ones
Any suggestions?
At the top of the Settings dialog, there's an Export button. It creates a text file with an alphabetized list of all variables.
In that file, each variable is on a separate line, with comma-delimited fields for type, where stored, current value, and a brief description. So you can open it in a spreadsheet program to make it easier to use.
Thanks Anthony. That's a great starting point
