New paper space layout tab position
Hi all, When I create a new layout the position is to the righter the layout that I am copying, I think I remember it used to be added to the end of the layouts
  • In v17 a new layout tab is always placed on the far right end of the tabs, even if it's created by copying the current layout.
    But I always wish it would be as you described, i.e. to the immediate right of the current layout's tab.
  • thanks you Anthony, I am using V20 and it is set just as you want, so it must be a setting that has changed. IF i find the setting I will let you know
