Refer to other parameter in BOM
Hello,
Is it possible to refer to a different parameter in the BOM? See attached screenshot.
I can add the column, but then I have 2 columns and with every part is one empty.
Thank you in advance!
Hello,
Could you please provide a sample file(s) and explain the needed result in a bit more detail?
Hello Ilya,
In our BOM template we use the part description for the name of the parts.
With the standard parts he uses the same description for all entities, even with a different size.
For example PIPE has many SIZES but only one description. I would like to know if is possible to refer to antoher parameter without having an extra column. -
Hello,
Could you please file a support (feature) request here: https://www.bricsys.com/protected/support/NewSupportRequest.do?categoryID=139
The possibility you requested is actually under development now.
Howdy, Stranger!
