MTEXT Dialog Box
Although working perfectly for years, have suddenly lost the MTEXT dialog box. I can select it and change the text, but without the dialog box, can't change the text height, justification, linespace, text width, etc. Using v20 (and has worked previously in this version). Works as expected in v19.
Have already tried MTEXTED->Internal, and ALT-TAB to make sure the box wasn't hidden somewhere.
May not be related but noticed in Mtext you have to mouse click inside the text box to start editing.
The latest update did this, will take getting used to.Anyone know what was wrong with the way it was?
Hi Tim, that MTEXT focus issue was not intentional. We released a hotfix, 20.2.08, with a fix for the problem.
Thanks Owen!
