Ok, I have a sub that creates a block that consists of a polyline and an attribute. It worked just fine in AutoCAD, but not in BricsCAD.
I have made some changes to get it to work with BricsCAD, but it still doesn't work.
It stops at the line: deltaBTR.AppendEntity(deltaPoly)
Imports System.Text
Imports System.Runtime.InteropServices
Imports System.IO
Imports Teigha.Runtime
Imports Teigha.DatabaseServices
Imports Teigha.Geometry
Imports Bricscad.ApplicationServices
Imports Bricscad.Runtime
Imports Bricscad.EditorInput
Imports _AcRx = Teigha.Runtime
Imports _AcAp = Bricscad.ApplicationServices
Public Sub CreateDeltaNoteBlock(ByVal dwg_scale As Double)
Try
Dim podDWG As Document = Application.DocumentManager.MdiActiveDocument
Dim podDB As Database = podDWG.Database
Using deltaTrans As Transaction = podDB.TransactionManager.StartTransaction
Dim deltaBTR As BlockTableRecord = New BlockTableRecord With {
.Name = "Delta_Note"
' Add a polyline and attribute to the Block
Dim centerPoint As Point2d = New Point2d(0, 0)
Dim distFromCenter As Double = 4.944
Dim delta_pt1 As Point2d = PolarPoints2D(centerPoint, degreesToRadians(201.0), (distFromCenter * dwg_scale))
Dim delta_pt2 As Point2d = PolarPoints2D(centerPoint, degreesToRadians(219.0), (distFromCenter * dwg_scale))
Dim delta_pt3 As Point2d = PolarPoints2D(centerPoint, degreesToRadians(321.0), (distFromCenter * dwg_scale))
Dim delta_pt4 As Point2d = PolarPoints2D(centerPoint, degreesToRadians(339.0), (distFromCenter * dwg_scale))
Dim delta_pt5 As Point2d = PolarPoints2D(centerPoint, degreesToRadians(81.0), (distFromCenter * dwg_scale))
Dim delta_pt6 As Point2d = PolarPoints2D(centerPoint, degreesToRadians(99.0), (distFromCenter * dwg_scale))
' Create the polyline
Dim deltaPoly As Polyline = New Polyline()
deltaPoly.SetDatabaseDefaults()
deltaPoly.AddVertexAt(0, delta_pt1, 0, 0, 0)
deltaPoly.AddVertexAt(1, delta_pt2, 0, 0, 0)
deltaPoly.AddVertexAt(2, delta_pt3, 0, 0, 0)
deltaPoly.AddVertexAt(3, delta_pt4, 0, 0, 0)
deltaPoly.AddVertexAt(4, delta_pt5, 0, 0, 0)
deltaPoly.AddVertexAt(5, delta_pt6, 0, 0, 0)
deltaPoly.Closed = True
' Add the new object to the block table record and the transaction
deltaBTR.AppendEntity(deltaPoly) '<--------Stops here --------
'Sets the bulge at index 0, 2, and 4
deltaPoly.SetBulgeAt(0, (Math.Tan((120 / 4) * (Math.PI / 180))))
deltaPoly.SetBulgeAt(2, (Math.Tan((120 / 4) * (Math.PI / 180))))
deltaPoly.SetBulgeAt(4, (Math.Tan((120 / 4) * (Math.PI / 180))))
' Add an attribute definition to the block
Using deltaAttDef As New AttributeDefinition
deltaAttDef.Position = New Point3d(0, 0, 0)
deltaAttDef.Prompt = "Enter Delta Number: "
deltaAttDef.Tag = "DeltaNote"
deltaAttDef.Justify = AttachmentPoint.MiddleCenter
deltaBTR.AppendEntity(deltaAttDef)
'deltaBT.UpgradeOpen()
'deltaBT.Add(deltaBTR)
End Using
Dim deltaBT As BlockTable = DirectCast(deltaTrans.GetObject(podDB.BlockTableId, OpenMode.ForWrite), BlockTable)
'Dim deltaBT As BlockTable = podDWG.Database.BlockTableId.GetObject(OpenMode.ForWrite)
'Commit the Transaction
deltaTrans.AddNewlyCreatedDBObject(deltaBTR, True)
deltaTrans.Commit()
'Dispose of the Transaction Objects
deltaTrans.Dispose()
End Using
Catch ex As Exception
MsgBox(ex.ToString, MsgBoxStyle.Information)
End Try
End Sub
I would really appreciate some help on this, thanks.
Answers
This seems to have fixed it:
