Copyclip is not selecting annotative entities
in Other
If I use COPYCLIP, select items, and then use PASTE, none of the annotative entities are selected and redisplayed in the paste.
ANNOALLVISIBLE is 1 but same thing happens with ANNOALLVISBLE is 0
If I bring the drawing up in autocad this does not occur.
Is there a setting combination that would cause this??????
Dear David
I tested this in a drawing of my own, but could not reproduce the problem. Can you file a support request and add the drawing you are having this issue with?
https://www.bricsys.com/protected/support/NewSupportRequest.do0 -
Erased.
