Copyclip is not selecting annotative entities
in Other
If I use COPYCLIP, select items, and then use PASTE, none of the annotative entities are selected and redisplayed in the paste.
ANNOALLVISIBLE is 1 but same thing happens with ANNOALLVISBLE is 0
If I bring the drawing up in autocad this does not occur.
Is there a setting combination that would cause this??????
Hi David,
I believe it is a bug, and worth raising a support request on to get it fixed. From what I've seen
PASTECLIPfor annotative objects is successful, but all the scales related to the entity are removed, effectively making it invisible. You can fix by usingQSELECTor the Structure Panel to select, then either add a scale from the Property Bar or theOBJECTSCALEcommand.Regards,
BricsCAD V20 Ultimate
CAD Concepts0
