ATTIN / ATTOUT
Anybody know if there is a BricsCad equivalent for the Auto-Cad command ATTIN / ATTOUT
  • There is plenty of lisp out there to do attout etc a Attin is slightly different and is a current discussion at forums/autodesk.
    Need more info about what it is your trying to do all in model ? Titleblocks etc.
  • REGARDING COMMAND ATTIN AND ATTOUT USED IN AUTODCAD,
    I'M LOOKING THE BRICSCAD EQUIVALANT COMMAND
  • @PeterFaherty Since you posted the same request twice, you may also want to look at that other topic.
  • Someone knows the equivalent AutoCAD command ATTIN / ATTOUT?
  • Attin & Attout appears to work in V24.
  • ATTIN and ATTOUT commands are present in BricsCAD. In V23 and V24 they are directly included and in past versions they are included in Express Tools that you can install: Site faviconBricsCAD Application Store | Bricsys
