Workspace issue.
Not sure how or why this occurred but it has been driving me crazy. The command line palette and the properties palette always jump to the center of the screen when I first open the program (see attached image). I have tried playing with palette settings. I move them over to my second monitor when I first open the program, they do not get saved in the new location when I close out. I have tried saving a new workspace after I move them, doesn't work. I have the same version on my laptop which works fine, I even imported the workspace from that machine, but it did not correct the problem on my work station.
Version 20.2.09, on Win 10
AFAIK there is already a 20.2.10,
but quite unlikely that would help.I think more about something went wrong in your Settings in "Config" File.
Just tried updating to the latest version, no help.
Initially this fixed it. After resetting the defaults I could open and closed the program and the workspace was saved (docked on one monitor). Then when I started dragging them over to the other monitor and closed the program the panel locations were not saved. Upon reopening the program the panels were snapped to the center of the screen again.
If you can reproduce thit behavior, it should be a bug.
It would be nice to file a Service Request, so they can
fix it.0
