composite panel "Alucobond" etc.
Any solution in sheet metal for composite panels bending and unfolding?
regards.
  • Its possible to add a bendtable for specific materials.
    If your supplier can give you the correction values per thickness and angle you can add those to Bricscad.
    Bricscad will then use those values when generating flatpatterns.
  • Isn't the problem with bending composite panels,
    that those usually get cut outs so that only the most outer
    Ply only will be bent, for a smaller radius ?
  • Hi,
    maybe i'm wrong, but the bending lines from the BricsCAD sheet should be on the right position for the milling of the groove.
    (We have in our application a solution for 2D drafting. )
    Regards
    Wolfgang
