Editing curtain walls
Hi!
I'm pretty new to the progam so this will probably be the first of many questions :). But is it only possible to edit the dimensions of curtain walls manually in the block editor? Why aren't the parameters visible in the property panel like with windows?
Thanks!
  • I think that would be a very good idea.
  • @Eva777 , you should file a feature request for this.
    In June, I filed SR103614 asking for similar functionality with BIMWindowCreate. I promptly received a reply to my support request, which said they had added the feature to their development "roadmap", although to my knowledge it did not make it in time to be part of the latest v21 release.
