Civil - add a corridor to a section
Hi
I have created a section through a road cross drainage culvert using a tin of an existing surface and an alignment string. I have modelled a road and the culvert as corridors. Is possible to add the corridor meshes to the vertical alignment view?
Cheers
Brian
Hi Brian
In BricsCAD V21 it is not possible to add corridor mesh to the vertical alignment view. But this is something it would be good to have. Added to the civil wish list for future releases.
Andrej
Howdy, Stranger!
