SUMs in tables not working
This is huge because I will have to switch back to Autocad. Are Sums in tables broken? Every sum I get #### when its exactly what I want to sum. I have tried with a simple table. Please help if there is a work around. Or is this fixed in v21? If so how do I get into the beta? I am a paying customer btw. I know there is the work around of adding each row individually but is that the only way?
Thanks,
Russell
Is this working in V21? Just got yelled at from my boss because the A/C tabulation was messed up on a plan.
As far as I can tell with a quick test it seems to be working ok in V21. Could you share a sample table because your original post is not entirely clear on what the issue exactly is.
You can send a Service Request, say that you want to participate testing and ask for Beta access.
At least that's what I did at that time.0 -
Ok I will do that. Thanks
Yea I am on Mac and V21 isn't out yet. I will just change them to B2+B3+B4....If I dont touch an existing table it doesn't mess up so I will just have to be extra careful until V21.
