Using command function for hatch has changed in ver. 20.2.09 ?
Hi Forum,
Seems like the hatch command has changed in the 20.2.09 subversion.
This is workiing fine from v. 16 to v. 20.07:
(Command-s "_.hatch" "P" "ANSI31" 10 0 "S" (entlast) "" "")
But from ver. 20.2.09 it does not accept the "select entities" and (entlast), it gives this error:
Not opened for read
Can somebody help me with a lisp workaround for this?
BR
Carsten
Problem solved, when changing the selected entity for hatching from a block to a rectangle.
Howdy, Stranger!
