Can't make coil sweep smooth - V20
See attached image. Trying to smooth the coil sweep, looks rough. The commands I've used in previous versions like viewres or
facetres no longer have an affect. Regen does nothing either. Is there a new setting toggle I'm missing?
Noticed this difference between V21 and earlier releases a while back and submitted a support request on it. Still open.
Try turning off spaUseFacetres and set spaSurfaceTol to a value which smooths out the appearance. The difference in behavior is still there but tweaking those two settings can improve the appearance.
Thanks Richard but it has no effect. Tried V18 and the coils look the same. Wonder if the sweep command
is the culprit. I checked the helix (path) and it's smooth. Hopefully they'll get this fixed.0 -
Just for the record, support had me change to these settings which worked!
SpaUseFacetRes = 0, SpaSurfaceTol = -0.25, SpaNormalTol = 15 and SpaMaxNumGridLines = 2048.
Thanks for the update! Clipped and saved.
