Viewport standard scale in imperial
SCALELISTEDITallows you to edit the scale lists for the current drawing, including an option to revert to system defaults.Use
DEFAULTSCALELISTto set your system default scale lists. There are two lists that can be set:Regards,
BricsCAD V21 Ultimate
CAD Concepts0
