Problem with 2D Dimensions
The bottom extension line goes through the Alternate units. Same thing in the preview. This is unacceptable and ridiculous.
Try changing the Dim suffix from
"\Xto"\P.0 -
THANK YOU !!!! THANK YOU !!!! THANK YOU !!!! THANK YOU !!!! . . . . . . . THANK YOU !!!!
Your suggestion fixed the problem described above. This problem is the only one I have not been able to overcome since I bought BricsCAD and thus a source of great frustration. That script was from a drawing file I had done with ACAD.If possible could you direct me to the article that explains the script??
Again - Thank you0 -
\Pis an Mtext format code:
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-7D8BB40F-5C4E-4AE5-BD75-9ED7112E5967\Xis not mentioned on the linked page. I believe it is only used for dimensions. If\Xworks in AutoCAD then you should send in a support request so that this incompatibility can be fixed.0
