Bricsys - Maptrim
Hello
Is there an option in Bricscad to trim elements limited by a fence. I mean the function of Autocad map - Maptrim
Best regards
Grzegorz
@GrzegorzP said:
Hello
Best regards
GrzegorzSo I did a bit of research online to see if I could find a command comparable to MapTrim. While EXTRIM is available, it doesn't appear to produce the same outcome.
I'm continuing to do some additional investigation and will let you know the outcome.
Much appreciated,
-Craig0 -
Sent a request to support.
SR118165 - Feature Development - MapTrim0 -
I believe there is a cooky cutter function in the Express Tools:
https://www.bricsys.com/applications/a/?express-tools-a589-al1002You can also try:
http://www.b-k-g.nl/bkg_extrim.html0 -
I have Bricscad v19 and MapTrim.lsp doesn't work for me cause i don't have extrim.lsp.
I have instaled express tools and now i have extrim command.
It is little similar to maptrim but not exactly the same.
http://www.b-k-g.nl/bkg_extrim.html is similar to express tools extrim.lsp i think.
Thanks for help0 -
Could you explain what behavior are you looking for? I ran the 'desks MAPTRIM and noticed it does not appear to allow for multiple boundaries, etc.
We're always looking for useful additions to our add-on package.
