Aerial Image assingned to a box.
How does one attach a aerial image to a 3D solid box 1:1?
I want to use this to export to fbx. The image is exact the same size as the solid.
In the mean time i just keep trying some
Thanks!
Hi Hans,
I opened your file and made a quick assignment,
Open Materials, and changed your material
assign the areal PNG to the diffuse "slot"
select the solid and change the Material in the properties window to the material created
in your material settings the map transformation scale is set to width 1 and height 1
The solid is mapped with the settings 1:1
change the height and width to the solid dimension
regen
then export fbx
this is the "material" saved in the fbx.file viewed in another 3D viewer
