AcDbCivilTinSurface::triangles on brics 2021
function TinSurfaceTriangles ::triangles returns an array of triangles- each triangle includes 3 identical points (unlike B20, where it works fine).
Is there any workaround?
Thanks,
Simon
I can't reproduce that problem (works here) on 21.1.04 (x64) revision 86916 using .Triangles. Are you using the .Triangles or .GetTriangles(includeInvisible As Boolean)?
I am using
virtual bool triangles(AcTinTrianglesArray& triangles, const bool visibleOnly = false) const;
on 21.1.05 (x64) revision 87753 and BRXSDK_r15543_for_Bcad_V21_1_040 -
Dear All,
yes, unfortunately there was such a defect in the mentioned function :-(
Will be fixed in next BricsCAD update ... coming soon.many greetings !
To check I installed 21.1.05. You must be using BRX (not .NET) because I don't see a match for that. The C# .Triangles (which works) is ...
public System.Collections.Generic.IEnumerable Triangles { get; }
Member of Bricscad.Civil.TinSurfaceStaticI would suggest you submit a support request, they seem to be quite responsive to developers needs lately.
