Change radius of existing fillet
I have a 3DSolid and used dmfillet to apply a radius to one edge (an intersection of two faces). How do I change the radius? Or how do I remove the fillet so I can create a new one with the necessary radius?
  • Doesn't the PushPull Tool work to resize the Fillet or at least pull it out to make it disappear ?
  • edited December 2020
    PushPull allows changing the radius but removing the fillet doesn't seem to work. Or it's just inconsistent.
    To remove a fillet - instead of trying radius = 0 with pushpull - I found selecting the 3D face representing the fillet and pressing Delete does the job. This results in the faces intersecting minus the fillet.
  • So I learned something new ....
