MOVING MULTIPLE ATTRIBUTES IN A BLOCK
Hallo
I have tested a block with 3 attributes inside and its working ok. When I try to reposition the attributes of this block though I have to move them independently, one at a time. is there a way to connect them so they can be moved toghether ? Parameters do not work, groups are not working as well.
any ideas ?
thanks
Luca
If you were to consider third party add-ons, DotSoft's ToolPac contains an Attribute Move command that lets you select any number of attributes in a BlockReference to move. On BricsCAD v20 or higher you can see the attributes drag as you pick a new location.
