Joining Solids
Hi!
I am new to BricsCAD 3D modeling and i have a basic question i guess. Cannot seem to fins an answer anyway
So i create a 3D solid, then I extrude a hole in the solid. After a while i decide to fill the hole again. How can I join the 2 solids into 1 now: (the hole and the erest of the 1st solid drawn)?
I have tried the commands: JOIN, UNION, CONNECT,... nothing seems to work. I also cannot use the BIM tools
I am attaching a picture where u can see the filled solid (with the hole which was filled).
Can someone help me please?
Thank you and kind regards!
Borut Orel
The UNION command unifies 3D solids.
See https://help.bricsys.com/hc/en-us/articles/360006592294-Union
To delete a hole in a 3D solid, select the faces of the hole, then launch the Erase command.0 -
Hello Louis!
Thank you for your response. I would like to ask you how do I select the faces of the hole?
I tried using the tool "Prioritize selection of faces" but it does not work.
Any ideas?
Thank you and kind regards!0 -
Thank you. This helped a lot
Best regards!
Borut Orel0 -
When using Window select you can use the Ctrl-key to cycle between select solid - select faces - select edges. The icon next to the cursor and the Hotkey Assistant widget indicate the current selection mode. See movie in attachment.
