Is it possible to turn on 'ESNAP' for blocked geometry?
Multiple blocks intersecting (2d geometry) does not tigger ‘ESNAP – intersection’ function to work. Is this intentional in Bricscad (for example in purpose of boosting the performance) or is there somewhere a setting to turn it on?
I could theoretically imagine working with: Entity Snap Tracking to bypass this by marking all endpoints of segments that I would like the intersection to appear, however with curved geometry that is blocked the entity snap tracking could be not sufficient facilitation.
Never noticed this... quite a funny one:
It only happens if you intersect two instances of the same block, generally intersection snapping does work across blocks, see your example with additional blocks attached.
You should open a SR for this to be corrected.
Howdy, Stranger!
