Error: Invalid owner Object
I have an assembly with 2 sub-assemblies which will not update after I have changed them in some way, i keep getting: Error: Invalid owner Object.
So if I open one of the sub-assemblies within the top-level assembly they are correct and up to date. But once saved and closed they will not update within the main assembly.
Am I missing something, is this an operator error ?
I hope this is something I am doing wrong and not another bug, I'm getting tired of reporting bugs and have yet to use Bricscad Mechanical in a professional and productive way at all, very disappointing....
Hi Alex, hard to answer without having the dwg files. If possible, post the package with files.
Thanks Daniele, I'm unable to share the files because they are for a client and have NDA in place.
Digging deeper I think it could be because I am using 2 different computers to edit the files which is synced over PCloud, therefore the mapped location is slightly different.
I remember having this problem with Inventor and if the mapped location is different then part files are not found. I could be wrong....
I'm still confused how Bscad handles parts/components I have created, some parts I have created are external referances and some are embedded blocks yet they are a seperate files also?0
