ObjectId.GetObject(OpenMode.ForWrite) error
Hello everyone.
There is an error that occurs only in bricscad, so I ask a question
I am getting an error in the MoveCircle2 function below.
Is there a solution?
Imports Bricscad.ApplicationServices
Imports Bricscad.Runtime
Imports Bricscad.EditorInput
Imports Teigha.Runtime
Imports Teigha.DatabaseServices
Imports Teigha.Geometry
Public Class Class1
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim acCurDb As Database = acDoc.Database
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
<CommandMethod("MOVE-TEST")>
Public Sub MOVETEST()
Dim acCirc As Circle
acCirc = DrawCircle2(0, 0, 0.5)
MoveCircle2(50, 50, acCirc)
End Sub
Private Function DrawCircle2(x As Double, y As Double, r As Double) As Circle
Dim acCircD As Circle
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
Dim acBlkTbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
Dim acBlkTblRec As BlockTableRecord = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
acCircD = New Circle
acCircD.SetDatabaseDefaults()
acCircD.Center = New Point3d(x, y, 0)
acCircD.Radius = r
acBlkTblRec.AppendEntity(acCircD)
acTrans.AddNewlyCreatedDBObject(acCircD, True)
Application.UpdateScreen()
acTrans.Commit()
End Using
Return acCircD
End Function
Private Sub MoveCircle2(x As Double, y As Double, acCircM As Circle)
Dim moveAcCirc As Circle
moveAcCirc = acCircM.ObjectId.GetObject(OpenMode.ForWrite) '' //////////////// Error BricsCAD V20~
moveAcCirc.Center = New Point3d(x, y, 0)
moveAcCirc.Radius = 0.25
acTrans.Commit()
End Using
End Sub
End Class
try
// MOVETEST
catch (System.Exception e)
Bricscad.ApplicationServices.Application.ShowAlertDialog(e);
It will give you some ideia of what is happening.
And it's a good ideia using try/catch when interacting with elements of the drawing.
https://docs.microsoft.com/pt-br/dotnet/csharp/language-reference/keywords/try-catch0
