C#: Understand if a document is modified or not
Hi all!
I'm failing when trying to understand if a document has been modified after adding or updating a custom property.
I've a small piece of code which works on the current active document inside the Application and tries to update an existing custom property and add a new one.
Then it askes if the document is modified or not... but I always get that it is not modified, even though update and add routines have worked correctly.
public static void TestModify()
BRAPP BrxApp = (BRAPP)Marshal.GetActiveObject("BricscadApp.AcadApplication.21.0");
BRDOC BrxDoc = BrxApp.ActiveDocument;
AcadSummaryInfo Metadata = BrxDoc.SummaryInfo;
Metadata.SetCustomByKey("ExistingPr", DateTime.Now.ToString("HHmmssfff")); // it updates existing 'CompDes' property correctly
string pN = DateTime.Now.ToString("HHmmssfff");
Metadata.AddCustomInfo(pN, DateTime.Now.ToString("HHmmssfff")); // it creates this new property correctly
bool m = BrxDoc.Saved; // 'm' is always TRUE
What I've noted is that by adding or updating properties directly thru Bricscad GUI command (Menu\Drawing properties) the document is always modified (a '*' character is visible at the end of active file name... see attached image).
My questions are:
1. Is there another way for getting the modification status?
2. Is there a way for setting the document as modified/raising the document modification flag programmatically?
T&R,
LemonXXX
Please see DBMOD system variable, that should help here
