~~I have a chronic sticky mouse issue. Almost can't use use the software. It's slowing me way down. I've used V20 on this machine, although it's a new HDD.
Snaps/Osnaps off
Nvidia latest driver installed
Adequate hardware
glswapmode 0
Should I report as a tech issue?
Edit: when I open TOP in terminal, and I drag the mouse over objects (lines etc.) that seems to be what's causing it. It uses up to 60% of my processor for a second everytime it sticks over lines and objects. It's almost like it's trying to calculate something. I also noticed the sticking doesn't occur in 'settings' or outside the Bricscad environment.~~
Update: Solved
I turned off STATUSBAR and the issue seems to have disappeared. I also noticed recently when I selected the properties or osnap settings directly from the status bar it locked up Gnome hard. Alt+F2 wouldn't even work. That happened 2 or 3 times in the last month or so.
Something with the STATUSBAR doesn't agree with Gnome. May not be a Bricscad issue per-se, but something to possibly look into. Tech support was helpful.
Hi Rodolphe Simon,
maybe I'm a bit late... but I had similar problems when using Fedora w/ Gnome and some extensions, and in my case disabling hotkey assistant (at the bottom of Bricscad |HKA|) helped a lot. Since you've said that it sticks when hoovering over lines/objects then maybe also try disabling quad and rollover tips (|QUAD|RT|). In any case you should try to report such issues.
Hope this helps!
Thanks Andrejm. I'm going to refer this to tech support since nothing seems to work. There's some kind of problem with caching. I will post the solution here.
