BIM isolate given floor
Hello,
I have a multi-floor building model.
I have prepared SECTIONS for every floor - when I work (draw) on given floor I don't need to see other floors (so the other SECTIONS are turned off).
The problem shows when I try to switch to another floor - I have to turn off current SECTION and turn on the SECTION on destination floor. This takes time.
Is there any other (better) way to switch beetwen floors?
regards,
Warzyk
I am used to "isolate" my floors from Structure Panel.
But if you need Sections, you need to turn them on/off manually though.
As long as any horizontal Section below you Story of choice is active,
you would not be able to see it.0 -
How do You isolate from Structure Panel?
I can turn "on" and "off" given objects, but I could not find a way to turn "on" and "off" floor(s).0 -
When I use the BIM preset in structure manager I get my
Buildings/Stories/... in Hierarchy.So in Structure Manager, i hover with my cursor over the Story of choice,
right click "Isolate". So it will hide everything else and show my Story only.0
