2 starter questions: How to keep walls connected to eachother? Way to connect to grid?
Just started with BricsCAD BIM (with a little experience from Revit LT). Followed the basic tutorials and now trying to go a little deeper. And I was wondering:
1 - I have multiple walls that I connect to eachother. How to keep them connected when I move one wall to another place? There doesn't seem to be a connection between the two.
2 - Is it possible to connect for instance a wall or a building to a grid? That when I change the gridline the wall changes with it?
I know...these are newby questions, but I cannot figure out if (and how) to fix this? Many Thanx for your replies!
  • First question solved:
    1 - Use the BIM-drag tool: https://help.bricsys.com/hc/en-us/articles/360016537493-How-to-use-BIM-Drag
    Second question still open!?
  • 2.
    No, not possible to bind Walls to a grid.
    Same as Slabs can't be bound to Story Heights.
    On the other hand, with direct modeling tools, like BIM DRAG,
    you can move a slab vertically and all touching walls will follow.
    Or if you change a Grid Line, you can select a Face per each related
    Walls and drag them all at a time, without losing connections.
    Bricscad has a destructive modeling approach with clever Tools.
    Once used to that workflow it shouldn't be slower than more
    parametric modeling approaches.
  • Thank you for your reply Michael!
  • Hmmm...in the video from the Bricsys Help files the standard option with Drag is that entities stay connected...in my version it is standard that they are disconnected and I need to use the control to adjust this setting. Is there a way to change the standard value?
  • Michael Mayer
    edited February 2021
    Yes, unfortunately that changed lately.
    But there there should be a setting variable to switch back to previous,
    if I got that right.
    I just forgot which.
    It was in some BIM Thread lately .....
    I think, answered by @Louis Verdonck
