unwanted dimension behavior
Talking about dimensions style: I would like the text to be always between extension lines and be able to move it with a leader.
when I select this options, I cannot decide where to put the text when dimensioning an arc: as soon as I click on the arc, the quote is placed and fixed to that point, external to the arc, and I must end the command and edit it to change the "rotation".
this doesn't happen if I select the option to keep dim line with text: I click an arc and decide how much rotate
