Does somebody has an idea which command or variable has an impact on the way how the corners of polyline will be printed.
Some times a polyline (linetype: dashed) has a gap right at the corner but that becomes visible just at printing (look at the attached file)
How a linetype is applied to a polyline is determined by its 'Linetype generation' property. For the polyline in your example it is enabled. The difference that you see is a linetype scale issue either caused by the PSLTSCALE or the MSLTSCALE variable.
