Line smoothness
Since I changed my monitor and PC, and after reinstallation diagonal lines and curves don't look smooth.
I tried quite a lot of setting changes, and visualstyles changes, but nothing seems to work.
Gcsmooth is fpr splines, WHIPARC not doing anything, edges setting same, RedSdkLineSmoothing same.
So if anyone has any suggestions I'll really appreciate it.
Change your AntiAliasScreen setting.
Antialias settings are for improving when Lines at non 90° angles look Jaggy on screen.
Other quality settings called like curve deviation or similar are needed when curved
geometry looks polygonal instead of rounded.0
