MLeaders - Ortho
in 2D Drafting
Maybe somebody can help. When doing a new mleader note on a drawing, after the 1st point and going for the 2nd 'landing' point, the tool will not obey the ORTHO key (F8) restrictions. It remains loose and thereby an additional step is needed to "line things up" properly. Is there a setting for this? or is this just the behavior in BricsCad? (In autocad, the mleaders will go fully horizontal or vertical when the (F8) is engaged, which helps a lot during production.
Any help is appreciated.
Thanks in advance.
T.
