How to encrypt my lisp code and deploy to client
Dear All ,
I am working with AutoCAD and BrisCAD , lisp development . I deploy my .FAS with autoCAD, but how can i deploy fas or lsp to deploy with briscad.
Please help me to encrypt my lisp code for briscad. suggest me any tool will help me.
thanks
vilas jadhav
9717409993
Hello,
BricsCAD orivides the DEScoder.exe utility - compatible with FAS/VLX projects from AutoLISP;
so you can use the same prv/prj project for both systems.Encrypted files are named .des - AutoCAD loads .fas + .vlx files, BricsCAD loads .des files;
to be smart, just use
(load "name")
and do not use (load "name.vlx/fas/des") so that each CAD system automatically detects its appropriate file (if all fas/vlx/des files are in same location).You can download our "Lisp Developer Support Package" - freeware from ApplicationCatalog :
https://www.bricsys.com/applications/a/?lisp-developer-support-package-(ldsp)-a720-al1176hope this will help you ?
many greetings !0 -
Question:=
Please, you help me , how we can transform "PROCESSOR_IDENTIFIER" to Word-Pin?(for selling lisp on internet)?
Now You can encrypted all sources.lisp-ascii with OsMode.You cannot execute the "pp_rolisonfelipe_jcpin25.lsp" without Osmode=598.
Your card bank contains Pincode(xxxx-digits)
(PROCESSOR_IDENTIFIER "x86 Family 6 Model 23 Stepping 6, GenuineIntel").
Now , even your-program.lsp, contain pinCode.lsp (e.g. pp_rolisonfelipe_jcaro10.lsp)0
