BricsCAD BIM wblock, UCS/WCS away from insertionpoint
in 3D Modeling
Problem: when I open the BricsCAD BIM drawing which i exported as block the UCS/WCS is away from the insertion point
What did i do:
Opening a new file with the default bricscad bim metric mm template I draw somewhere a box.
Export element as a block (wblock) I select a special insertion point.
When I open that file the UCS/WCS is - i think - the same as the original drawing from where i made the wblock.
When I insert the block (insert) the insertionpoint is the same as when created the block.
