Text Align - is there an equivalent command to Autocad TEXTALIGN in bricscad?
aridzv
edited March 2021 in 2D Drafting
is there an equivalent command, or other way, to Autocad TEXTALIGN command?
I've attached a picture showing what I need to do.
Thanks,
Ari.
  • I don't know of a command but you can select one. copy it's x postion in the properties window. Then select the rest of the text and past that number into their x position and they will all be aligned as long as they were using the left justify.
  • aridzv
    edited March 2021
    Well,
    it looks like there is no straight forward solution in bricscad,
    so Lee Mac to the rescue again... -:)
    I've found a lisp that do the job in this Lee Mac link: http://www.lee-mac.com/aligntext.html
    Ari.
