v21 Point cloud .rcp file
Hello. I am trying to import a point cloud into V21 BricsCAD BIM from an .rcp file. When it is imported however the scans are not lined up well and it looks like a bit of a mess. All the Bubble views are kind of in the same spot. The same file loaded into AutoCAD 2021 looks fine though, no pre-processing. But they don't do bubble views. I tried an .e57 file and it loaded in nicely, especially compared to the same scan(s) in .rcp format. Any advice would be very much appreciated. Thanks
Hi Penelelop,
It is hard to tell why this issue occurs. Can you please file a support request so our developers can have a closer look? https://www.bricsys.com/protected/support/NewSupportRequest.do
Kind regards,
Chi-Yan0
