I've found the attached lisp that label contours.
the problem is that it for PLINE (x,y and Elevation)
I need help with changing it to work with 3DPOLYLINE (x,y,z), and the use the Z value of the first vertex of every line as the contour level value.
(actually, we can use any vertex of the contour line for the elevation value... I just thought it will be easier to use the first...)
Thanks,
Ari.
Answers
Instead of changing the Lisp, you need to convert your 3dPoly objects to LwPoly objects using the elevation of the first vertex. This will make for a more compact drawing file and your drawing will look more professional to anyone who receives it.
You could request the DotSoft MapWorks 45-day full working evaluation to do this and it's likely you will like it's contour labeling options better as well.
@Terry Dotson Hi and thanks for the reply.
have a look on this autocad add-on:
https://apps.autodesk.com/ACD/en/Detail/Index?id=1924449314298874554&appLang=en&os=Win32_64
do you have something like this including pricing?
thanks,
Ari.
One more thing - it is simple to change the contour to LWPOLYLINE.
Let's say I will do it manually with CONVERTPOLY command and not trough the lisp.
Can you help with the code that get the first vertex elevation and asgin it to a variable?
Thanks,
Ari.
For a LwPoly, the last line of this, using pure native lisp (not activex).
O.K.
Here is a lisp that do it (see attached lsp file).
regards,
Ari.
