BIMPROPERTIES - How to apply a formula in Value?
Hi Again,
In BIMPROPERTIES, I created a custom property definition CostperMeter. Still in BIMPROPERTIES, now I want a Value that gets the multiplication of the LinearAxisLength by the previous property.
Using "LinearAxisLength*CostperMeter" or "=LinearAxisLength*CostperMeter" in the Formula field is not working.
Is it not possible, or what is my mistake?
TIA
Hi João,
Currently, it is not possible in BricsCAD to combine custom properties with Values, you can only use Core quantities in Value Formulas.
If this is an important feature for you, please file a support request to possibly give it a higher priority at https://www.bricsys.com/protected/support/NewSupportRequest.doKind regards,
Chi-Yan0
