Block insertion problem
When inserting a block while a rotated local UCS is active, leaving the defaults (pressing Enter), the block is inserted with default scale=1 (OK), but with rotation angle entered as 0 refered to GLOBAL USC instead of local UCS as expected. Zero rotation should be relative to local UCS, similar to coordinates? I think this is an error - at least compared to ACAD behaviour. Vaclav
I agree. Same goes for hatching, it is always relative to the global UCS, which it shouldn't be.
Any indication from BricsCAD that these errors will be gone in the next release? These really don't seem to be a serious problem to correct. And when is the next release expected? Regards Vaclav
